Logiciels et Firmwares
En route pour le 1.4.16
Archos 5 Internet Tablet
›› Télécharger l’OS v 1.4.16 pour Archos 5 Internet Tablet (75116Kb)
Version 1.4.16 – December 14th, 2009
  • Wi-Fi: improve scan performance and connection manager
  • Video: now display subtitles for HD videos
  • Video: fix MKV subtitles that were sometimes truncated
  • Video: improve youtube video playback
  • Video: correct playback of certain M4V/MP4/MOV files
  • Video: solve some videos not correctly displayed
  • Streaming: Archos Media Player couldn’t open http links containing special characters (space, coma, etc.)
  • ThinkFree Mobile 1.2: double-tap zoom in PDF, miscellaneous bug fixes and speed improvements
  • USB: fix transfer interruptions in USBnet mode
  • USB: accessory did not work when USB cable was connected in ADB mode
Rien de plus, toujours pas de Donut
6 réflexions au sujet de « En route pour le 1.4.16 »
  1. La solution proposée par le support Archos fonctionne parfaitement.
    J’ai juste modifié la commande qui modifie le fichier ~/.android/adb_usb.ini pour en préserver le contenu en exécutant la commande
    echo "0x0e79" >> ~/.android/adb_usb.ini
    Voici le résultat :
    $ adb devices
    List of devices attached
    $ adb devices
    $ more ~/.android/adb_usb.ini
    # ANDROID 3RD PARTY USB VENDOR ID LIST -- DO NOT EDIT.
    # USE 'android update adb' TO GENERATE.
    # 1 USB VENDOR ID PER LINE.
    $ echo "0x0e79" >> ~/.android/adb_usb.ini
    0x0e79
    $ adb kill-server
    $ adb start-server
    $ adb devices
    A5S-xxxxxxxx-xxxxxxxx-xxxxxxxx-xxxxxxxx device
  2. Fix to the bug on ADB mode connection with MacOSX
    Here is an information from Archos support that should solve the bug on ADB with Mac OSX
    ========= message from Archos support =========
    You actually need to modify or create the adb_usb.ini file
    In terminal, you need to type :
    echo « 0x0e79 » >~/.android/adb_usb.ini
    Then ./adb kill-server and ./adb start-server
    ========= end of message from Archos support =========
    I will test test that solution tonight
  3. J’ai installé le driver Paragon ExtFS for Mac OS X (http://www.application-systems.fr/paragonextfs/)
    Sur MacOSX 10.6.2 avec le kernel en mode 64 bits, on voit l’A5IT dans DiskUtility mais pas le filesystem. Et on ne voit rien dans le Finder.
    Lorsqu’on redémarre le kernel en mode 32 bits, le filesystem de l’A5IT apparait correctement dans le Finder.
    J’ai copié quelques fichiers et cela marche correctement, mais il y a des lenteurs.
    L’éjection de l’A5IT depuis le Mac ne fonctionne pas correctement : il faut en plus démonter (unmount) la connexion depuis l’A5IT et on obtient un message d’alerte sur le Mac !…
  4. Bug en mode ADB sur Mac OSX 10.6.2
    Cette nouvelle version ne corrige toujours pas le bug dans la connexion en mode ADB sur Mac OSX 10.6.2
    « adb devices » ne trouve pas l’A5IT
    Bug déjà signalé sur la 1.4.08 (http://www.jbmm.fr/2009/11/26/2-firmwares-sinon-rien/) et la 1.4.09 (http://www.jbmm.fr/2009/11/28/et-hop-un-firmware-archos-5it/)
    Avant de décider si je repasse à nouveau en 1.3.07, je vais tester le driver Paragon ExtFS for Mac OS X signalé par archoslounge.jbmm.fr (http://archoslounge.jbmm.fr/Archos-5IT-et-le-Mac-LA-solution,9220.html)
  5. Thinkfree n’indique pas de version 1.2 mais 1.1.1013.04…
    Etrange « nouveauté » : maintenant, l’archos fait sa mélodie à l’extinction… reste à voir si on peut paramêtrer son absence
