Le nouvel Archos Diamond Omega
Et donc Archos propose un nouvel avatar de Diamond Omega avec le (Nubia Z17s) Borderless…pour 499€
Le PDF ARCHOS_Diamond_Omega
Page Produit http://www.archos.com/fr/products/smartphones/diamond/archos_diamondomega/index.html
Ces caractéristiques sont :
Hardware
CPU: Qualcomm® Snapdragon™ 835, 10-nanometer design, 8x 64 bits Qualcomm® Kryo™ 280, 4x Kryo @ 2.45 GHz + 4x Kryo @ 1.0 GHz
GPU: Qualcomm® Adreno™ 540 @ 710 MHz
RAM: 8GB, LPDDR4X
Internal Storage: 128GB, UFS2.1 Gear3 2L
Size & Weight: 147.46×72.68×8.5mm; 170g
Screen
Diagonal Size: 5.73 inch
Definition: 2040×1080 (Full HD)
Resolution: 404 PPI
Technology Type: LTPS (IPS)
Multitouch: 10 points
Lamination: Full lamination / OnCell®
Protection: Corning® Gorilla® Glass
Luminance: 470 cd/m²
Supplier: Japan Display Insdustry (JDI)
Software
Operating System: Nubia UI 5 based on Google Android 7 Nougat
Application Store: Google Play
Voice Assistant: Google Assistant
Google Apps Preinstalled: Gmail, Calendar, Maps, Play Music, Play Movies
Email Compatibilities: POP/IMAP/ Exchange Active Synch/ SMTP/Push Mail
Wireless Technologies
SIM Placement: Dual SIM
GSM / GPRS / EDGE Frequencies: 850 / 900 / 1800 / 1900 MHz
3G / WCDMA Frequencies: 850 / 900 / 1900 / 2100 MHz
4G / LTE Frequencies: 800 / 1800 / 2100 / 2600 MHz
SMS/MMS: Yes
Wifi: Yes, 802.11 b/g/n/ac
Wifi Direct: Yes
Bluetooth: Yes, Bluetooth 4.1
GPS: GPS, GPS+AGPS, GLONASS
NFC: Yes
Camera
Rear Camera (Dual Camera)
1x12MP Dual Pix (Sony IMX 362) + 1x23MP (Sony IMX 318)
2x6P Lens
1x f/1.8 + 1x f/2.2 apertures
NeoVision 6.0
Front Camera
2x5MP FF PureCell®
1x f/2.2 + 1x f/2.0 apertures
Video
Record Resolution: 4K (30 fps)
Play Resolution: 4K
Power
Built-in: Yes
Battery Size: 3,100 mAh
Battery Type: Li-ion
Standby time: 300 hours
Talk time: 1,000 minutes
Quick Charge: Qualcomm® QuickCharge 3
Charging Adaptor: 5V/1.5A, USB Type-C 2.0
Multimedia
Supported video formats: MP4, 3GP, MOV, MKV, AVI, FLV, MPEG
Supported audio formats: FLAC, AAC, MKA, OGG, MIDI, M4A, AMR
Supported image formats: JPEG, PNG, GIF, BMP, RAW
Ports and Sensors
Loudspeakers: Yes
Audio out: Type-C (adaptor included in the box)
Microphone: Yes
Light and Proximity: Yes
USB OTG: Yes
2D-G-Sensor / E-compass / Gyroscope: Yes / Yes / Yes
Le casque se branche sur l’usb-c
Et si vous aimez le chinois : https://www.nubia.com/nubiaz17s
Salut, super annonce, si je pouvais je me l’offrirai x)
