Archos 101 ChildPad sur le site d’Archos
Le voici, le voilà le dernier avatar de la gamme ChilPad : l’Archos 101 ChildPad
Caractéristiques
Caractéristiques
Storage | • Flash memory: 8 GB* • Expandable via micro SD slot |
Operating system | • Android™ 4.2, Jelly Bean |
CPU | • Rockchip RK3168 – Dual-Core ARM Cortex™ A9 @ 1.2 GHz |
RAM | • 1 GB |
Display | • 10.1” capacitive multitouch screen – 1024×600 pixels |
Video playback | • H.264 up to 1080p resolution – 30 fps • MPEG-4 – 30 fps With the above codecs, the device can play video files with the following extensions: .avi, .mp4 ,mkv, .mov |
Audio Playback | • MP3 , WAV (PCM/ADPCM), AAC, AAC+ 5.1, OGG Vorbis, FLAC |
Photo viewer | • JPEG, BMP, PNG, GIF |
Interfaces | • Micro USB 2.0: Mobile Transfer Protocol (MTP) • USB host via OTG • Micro SD • HDMI output (Mini HDMI / HDMI cable sold separately) • Audio Jack 3.5mm |
Communication protocols | • WiFi • Bluetooth™ |
Miscellaneous | • Figurine (see “Figurine technical specifications” below) • Front camera • 2 Built-in speakers • Built-in microphone • G-sensor |
Power source | • Internal: 5000 mAh Lithium Polymer battery • 5V/2A Power Adapter |
Battery life | • Video playback time: ??? |
Dimensions & weight | • 264.8 x 209.4 x 14.7mm • 639 g |
Compatibility | • Microsoft® Windows® 8, Vista, XP with WMP11, or higher • Mac OS. X with Transfer Files application (not included) • Linux with android MTP tool (not included) |
Computer interface | • Micro USB 2.0 interface |
Package includes | • ARCHOS 101 ChildPad, figurine, power adapter, USB cable, quick start guide (QSG), quick start guide (QSG) for kids |
Figurine technical specifications | |
Miscellaneous | • Built-in speaker • 2 LED (1 inside the figurine – illuminating when playing audio, 1 blinking while charging, on when charged |
Audio Playback | • MP3 |
Battery life | • Audio playback time: 20-30 min |
Functions keys | • Play, Pause, Stop, Volume up, Volume down, Next, Previous |
Page Produit : http://www.archos.com/fr/products/themed/childpad/archos_101childpad/index.html
Il est en vente chez ce revendeur : http://www.estock.fr/basketadd.php?partnumber=502535
1 réponse
[…] [Via] […]
