[màj] GEN 9 : Firmware 4.0.24 indisponible
MAJ
Il est retiré suite à de nombreux blocages, Archos va mettre à jour un nouveau firmware
Il faudra le mettre à jour via le recovery !
Un énorme mise à jour du firmware Gen 9 avec le 4.0.24
Télécharger l’OS v 4.0.24 pour Archos 80/101 G9
Changelog:
  • Android: IceCream Sandwich 4.0.4 version
  • Media Center: network indexing on network shortcut menu (+), network shortcuts creation is proposed on network share directory long press
  • Media Center: new simplified Movie/TV Shows/All Video views
  • Media Center Video: new video information view with backdrop display and chooser (click on backdrop to change it)
  • Media Center Video: poster can be changed by clicking on it in the video Information view
  • Video Scraper: faster media information retrieval process. Note that in the migration process, all your video scraper information will be lost.
  • Subtitles: ability to download and save subtitles for network shares
  • Media Center: add video search
  • Media Center Music: Album art swipe gesture support
  • Remote control: control your tablet with your TV remote through HDMI on TV compatible hardware (directional pad, multimedia and color TV remote keys)
  • Archos Remote: support of remote touch pad
  • Wi-Fi: new more robust driver
  • Media Center Video: fix audio desync for some MPEG4/AVI files
  • Media Center Video: fix MPEG PS/VOB audio track selection
  • Media Center Video: fix UPNP playback of large files (>4GB)
  • Media Center Video: fix seeking in some TS files
  • Media Center Video: fix playing certain MKV files
  • Media Center Video: fix playing certain H264 files
  • Media Center Video: improve DVD/VOB playback in case there are IFO files present
  • Media Center Video: add support for MPL2 subtitle format
  • Media Center Video: improve playback of H264/AAC TS files
Mais aussi :
  • Ajout du navigateur CHROME
  • Meilleurs performances
19 réflexions au sujet de “[màj] GEN 9 : Firmware 4.0.24 indisponible”
  1. maj faite en 4.0.24 et j’ai pas vu de grande difference de fluidité, pas de correctif sur les bugs multiples (freeze, reboot, …) par contre media center ne fait que planter, un comble pour archos. visiblement lié a un pb d’acces au dd…
    Retour en 4.0.7, alors la catastrophe, le media center me dit qu’il y a une erreur d’acces au disque interne….. Pourtant dans les parametres, tout a bien l’air là.
    Grrrrrr, j’espere qu’ils vont vite reagir chez archos…..
    Ça commence a etre saoulant ces bugs a repetition…. a croire qu’il les teste pas leur maj.
    La prochaine fois, pas sur qu’on m’y reprenne……
    Répondre
  2. des news, je viens d’avoir une procédure de rappelle ( à mes frais ) de mon archos.
    bref cela ne sera probablement que le 3 ieme swap en 6 mois 🙁
    Répondre
  3. Bonjour,
    Moi tout aller bien avec cette mise à jour. Mais j’ai eu le malheur de la laisser s’éteindre toute seule (batterie à plat) depuis elle veut plus rien savoir.
    J’ai branché le chargeur et le voyant clignote vite (bcp plus vite que lorsque la batterie est chargée). même constant en l’alimentant par le port USB. impossible de l’allumer. Je n’arrive même pas à faire afficher le logo archos.
    C’est grave docteur ?
    Répondre
    • Je réponds à moi-même.
      J’ai laissé la batterie chargée sur le secteur le temps de trouver une solution sur le net, et instinctivement je me suis retourné et l’écran était allumé.
      C’est tout de même une drôle de réaction! je n’ai jamais eu ce voyant clignoté aussi vite pour une batterie déchargée. Bizarre…
      pour le moment tout est donc revenu dans l’ordre. espérons que ça continue.
      Répondre
    • en fait, j’ai bien un problème. Mon chargeur et même mon câble usb sur le pc ne veulent plus charger la tablette. quand je branche le chargeur, la tablette fonctionne normalement, mais reste à 0% de batterie. si je débranche le câble elle s’éteint d’elle-même.
      Je ne me souviens pas avoir eu de problème lors de ma dernière charge et entre temps j’ai, par contre, installé la 4.0.24. est-ce que ça viendrait de là selon vous?
      Répondre
        • effectivement cela ne vient pas de là.
          Bizarrement la tablette ne charge pas avec le charge ni sur le port usb du PC, mais elle se met en charge lente quand j’utilise le chargeur de l’iPhone. c’est bcp plus long mais ça charge. c’est étrange ça.
          Répondre
          • j’ai eu exactement le même problème avant sans cette mise a jour en faite le problème vient de l’intérieur de la tablette il y a des câbles déconnectés entre la batterie et ou se branche le chargeur.(c’est ce que m’avait dit archos)
  4. Benchmark
    Informations à partir de Quadrant Standard
    Firmware Archos 4.0.7:
    Total : 1899
    CPU : 4789
    Memoire : 1543
    I/O: 788
    2D: 1000
    3D: 1377
    Firmware Archos 4.0.24:
    Total : 2071
    CPU: 4738
    Memoire: 2306
    I/O 907
    2D 1006
    3D 1399
    Des Performances sont constatées
    Répondre
  5. Bonjour,
    Mise à jour effectuée et personnellement aucun soucis à signaler.
    J’espère que la prochaine ne sera pas source de nouveaux problème justement.
    Il aurait mieux fait de libérer Jelly bean sur nos G9 pour faire ça, moi je dis ça mais je dis rien 😀
    Répondre
  6. je viens d’avoir le sav, qui me renvoie sur un recovery inexistant, j’en ai mal au doigt d’avoir appuyer sur la touche plus pendant 10 mn.
    je crois que c’est encore sav pour ma tablette…
    Répondre
  7. si ça peux aider
    80g9 etait figé sur logo archos, sans l’eteindre, j’ai débranché l’alim et branché sur PC, ça c’est débloqué.
    en esperant que ça marche pour vous
    Répondre
