Firmware Gen 9 et rapport financier en ligne
par
Publié
· Mis à jour
Le firmware 4.0.5
Télécharger l’OS v 4.0.5 pour Archos 80/101 G9 (190782Kb)
- Wi-Fi: fix slow throughput and disconnections happening on some access points
- HDMI: solve no sound or no video output issue on some TVs
- Bluetooth: make sure Bluetooth does not prevent device suspend
- VPN: fix VPN connection failing
- Touchscreen: avoid loss of first finger touch while tapping with second finger
Le Rapport financier
Articles similaires
Étiquettes : Archos Gen 9FirmwareRapport Financier
I install the new firmware 4.0.5 and unable to connect to a hidden ssid wifi. It has to be turned visible, else it is considered as out of range.
I install the new firmware 4.0.5 but the WI-FI reconnecting problem continue, only I see an efect in the touchscreen. Need other update!
sur une Panasonic TX-PF42G30 (télé rependue !) la sortie HDMI de ma 80gen9 1Go – 16Go, la sortie HDMI fonctionne en 3.2.80 mais pas en 4.0.5
