G9 : Firmware 3.2.46 en ligne, mais attention…
Il a été l’arlésienne du week-end, le voici en ligne
Vous pourriez un soucis de clavier qui peut être mis en arabe suite à la mise à jour.
Donc pour éviter ce soucis :
Paramètres/Langue et Saisie/Paramètres du Clavier/Mode de Saisie Actuel…
Version 3.2.46 – September 23rd, 2011
- Google applications: Google talk is now part of the firmware
- Audio/applications: improved volume control (better volume range, less glitches on notifications) leading to faster gaming experience on some 3rd party applications
- Wi-Fi: fix low throughput on some access points when using WPA2/AES encryption
- Camera: improve camera quality in high and low light condition
- Flash: added acceleration support
- Archos applications: many enhancements and fixes on Videoplayer, MediaCenter and Mediascrapper
- Media center: new elastic and overshoot effect on cover roll edges
- File Browser: better action support on multiple selections
- Media Scrapper: better handling and cleaning of data base in case of file removal
- Photo Frame: Floating Image 3.1.9 is integrated with fixed Picasa support, better background rendering and better memory management
- Music player: better protection of music player to avoid to get it killed under low memory condition
- Display: better quality SD video upscaling (e.g. on 1080p display)
- Video: improve SMI subtitle support
- Internationalization: Arabic and Hebrew translations have been integrated and a new specific « Archos keyboard » application has been included for supporting Hebrew and Arabic
- Network shares: shortcuts can be created by long press on a remote video folder in Archos media center
- Network shares: more robust streaming in case of IP renewal
- Memory: smaller memory footprint
- 3G key: updated APN list
- Power off: make sure to clear all alarms when powering off
- Hard drive based unit: enhanced power management
- Security: apply security fixes from google about DigiNotar CA certificate
You’re blogging has really come on when I look back over previous posts. Actually I arrived here from a forum on an unrelated topic. Worth surfing sometimes. Thanks.
