Logiciels et Firmwares
Archos Gen 8 : firmware 2.3.20
Firmware 2.3.20 à télécharger ici
  • Application: a new Archos remote service and universal Android application to control your Archos device remotely using Wi-Fi. It is intended to operate your Archos using any Android phone/device for instance when the Archos is connected to the TV
  • Application: a new Archos youtube application to easily view and play youtube videos
  • Network shares: samba network share transfer speed has been enhanced to support HD streaming
  • Network shares: password protected shares are now discoverable
  • Media library: improve indexing behavior and robustness
  • Media info scraper: more robust poster and information retrieval process for TV and movie shows
  • Media library cleaning: all multimedia information (movie/tv shows posters and indexation data) can be cleared through settings->repair/formatting/reset multimedia library entry
  • Contacts: fix importation and exportation of Vcards
  • Applications: fix sound muted when initiating a call with Fring
  • Screen snapshot: fix capture for all screens and TV
  • Camera: increase quality of 720P H264 recording (decrease blockiness effect)
  • Multimedia: improve UPNP stability preventing hangs when Wi-Fi connection stops
  • Multimedia: for shoutcast network streams display url, station, genre on MusicPlayer
  • Multimedia: fix next playing video being paused at start in folder play mode
  • Multimedia: MMS playback support has been fixed
  • Multimedia: MIDI playback support has been fixed
  • Multimedia: fix compatibility with Rhapsody player application
  • Audio: fixed alarm volume when headphone are plugged (was lowered)
  • Video: fix some MPEG2 files not playing correctly on A28
  • Video: fix seeking in AVI with layer2 VBR sound
  • MusicPlayer: display track number (like « 3/10″) for A43/A70/A101
  • Videoplayer: fix folder play mode with HD video
  • Subtitles: auto detect UTF8 codepage
  • Storage: remove disk damage notification happening sometimes even after a successful file system check
  • Peripherals: display a notification when plugging a USB device that requires more than 100mA current for A28/A32/A70 to provide feedback that it is not supported (e.g. some USB keys)
  • Battery: improve prediction of wake up time to shutdown the product when battery is low
  • Proxy: http proxy support has been fixed
  • Phone tethering: increase compatibility with Blackberry phones (introduction of a setting to enable TCP/IP header compression)
15 réflexions au sujet de « Archos Gen 8 : firmware 2.3.20 »
  1. impossible de faire une recherche le clavier du téléphone n’est pas repris dans la télécommande au contraire des touches sonores.
  2. @jean-archos : chacun a sa vision du monde, les geek testent avant les utilisateurs lambda 😉 Donc j’attend qu’un plus geek que moi se lance 😉
    @benmars : finalement la solution par apk est plus souple que de tout intégrer 😉
    Ce soir je verrais si les quelques avi qui ne pouvaient pas supporter de reprise en hardware marchent mieux …
  3. – L’appli télécomande, super, très pratique et méga simple à configurer.
    – L’appli youtube d’archos fonctionne vraiment bien, mais le lien d’une vidéo youtube dans une page web de se fait pas dans cette application. Uniquement avec l’officielle. Dommage
    – Navigation d’un dossier partagé avec mot de passe fonctionne enfin
    Le reste quand j’aurais eu le temps de tester
  4. Hé bien je me dévoue pour le test tiens… en cours de download…
    Je testerais l’application « remote » en même temps et je repasse ici apres faire les comms…
  5. @zearchos : oui oui, attendons tous, attendre est toujours la solution, il y en aura bien d’autres qui testeront pour nous!
  6. Et ben, c’est une jolie mise à jour a première vue.
    La première application peut être vraiment sympathique, usage a creuser 🙂
    Et du debug a bien tester…
    Sinon je vais peut être attendre les premiers retours histoire de voir s’il y a du négatif 😉
