Saturday 28 January 2006 à 15:55
![]() Membre Hyper Actif ![]() ![]() ![]() ![]() ![]() ![]() Groupe: Membres Messages: 1688 Inscrit: 16/03/2004 Lieu : Péronne en Mélantois (59) Membre No.: 479 J'ai : AV340 + AVCam 300 (à moitié morte) + DVR 100 |
CITATION PocketDivXEncoder (0.3.60) Template selected : Archos AV100/AV300 series ./mencoder.exe "C:\Documents and Settings\Sûgaku-sensei\Bureau\pde.avi" -af volnorm -srate 44100 -oac mp3lame -lameopts mode=2:cbr:br=128 -subfont-autoscale 3 -subcp "latin1" -font "C:\WINDOBE\Fonts\Arial.ttf" -noodml -vf scale=320:144,eq2=1.0:1.0:0.03:1.0 -sws 9 -ovc lavc -lavcopts vcodec=mpeg4:vhq:vmax_b_frames=0:vbitrate=584:vstrict=1 -ffourcc XVID -o "K:\pde_Archos.avi" >> 1.txt 2>> 2.txt ./mencoder.exe "K:\pde_Archos.avi" -noodml -ovc copy -oac copy -ffourcc XVID -o "K:\pde_Archos_.avi" >> 1.txt 2>> 2.txt ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Starting .\mencoder.exe... CPU: Advanced Micro Devices (Family: 15, Stepping: 0) Detected cache-line size is 64 bytes CPUflags: Type: 15 MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 0 SSE2: 0 success: format: 0 data: 0x0 - 0x3b6800 AVI file format detected. VIDEO: [DIV3] 560x240 24bpp 25.000 fps 703.9 kbps (85.9 kbyte/s) [V] filefmt:3 fourcc:0x33564944 size:560x240 fps:25.00 ftime:=0.0400 ======================================================= Opening audio decoder: [mp3lib] MPEG layer-2, layer-3 AUDIO: 48000 Hz, 2 ch, s16le, 112.0 kbit/7.29% (ratio: 14000->192000) Selected audio codec: [mp3] afm:mp3lib (mp3lib MPEG layer-2, layer-3) ======================================================= Opening video filter: [expand osd=1] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1 Opening video filter: [eq2=1.0:1.0:0.03:1.0] Opening video filter: [scale w=320 h=144] ======================================================= Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family Selected video codec: [ffdivx] vfm:ffmpeg (FFmpeg DivX ;-) (MS MPEG-4 v3)) ======================================================= Forcing output fourcc to 44495658 [XVID] Building audio filter chain for 48000Hz/2ch/s16le -> 44100Hz/0ch/??... Building audio filter chain for 48000Hz/2ch/s16le -> 44100Hz/2ch/s16le... Writing AVI header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. VDec: vo config request - 560 x 240 (preferred csp: Planar YV12) VDec: using Planar YV12 as output csp (no 0) Movie-Aspect is undefined - no prescaling applied. SwScaler: Lanczos scaler, from Planar YV12 to Planar YV12 using MMX2 videocodec: libavcodec (320x144 fourcc=44495658 [XVID]) High quality encoding selected (non real time)! ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. Flushing video frames Writing AVI index... Fixing AVI header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. Video stream: 402.443 kbit/s (50305 B/s) size: 1883432 bytes 37.440 secs 939 frames Audio stream: 128.000 kbit/s (15999 B/s) size: 607294 bytes 37.956 secs Starting .\mencoder.exe... CPU: Advanced Micro Devices (Family: 15, Stepping: 0) Detected cache-line size is 64 bytes CPUflags: Type: 15 MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 0 SSE2: 0 success: format: 0 data: 0x0 - 0x26f36a AVI file format detected. VIDEO: [XVID] 320x144 24bpp 25.000 fps 402.4 kbps (49.1 kbyte/s) [V] filefmt:3 fourcc:0x44495658 size:320x144 fps:25.00 ftime:=0.0400 videocodec: framecopy (320x144 24bpp fourcc=44495658) Forcing output fourcc to 44495658 [XVID] Building audio filter chain for 0Hz/0ch/s16le -> 0Hz/0ch/??... audiocodec: framecopy (format=55 chans=2 rate=44100 bits=0 B/s=16000 sample-1) Writing AVI header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. Writing AVI index... Fixing AVI header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. Video stream: 402.443 kbit/s (50305 B/s) size: 1883432 bytes 37.440 secs 936 frames Audio stream: 128.000 kbit/s (16000 B/s) size: 607294 bytes 37.956 secs ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ MP3 audio selected Voilà^^ Les formats audio/vidéo semblent standart... d'ailleurs aucun problème de lecture pour le fichier sur mon ordinateur mais mon av340 pense différemment Ce message a été modifié par Sûgaku-sensei: Monday 02 April 2007 à 18:37 -------------------- Si tu utilises Firefox 2, n'oublie pas ton dictionnaire : Rajouter le dictionnaire et Option/Avancé/Général/Vérifier l'orthographe lors de la frappe.
Sunday 29 January 2006 à 19:16
Novice ![]() Groupe: Membres Messages: 4 Inscrit: 21/01/2006 Membre No.: 4459 |
Alors d'abord un grand merci, bravo, magnifique, youpi a Wildelnab pour son travail sur PDE Alors j'ai rencontré le meme probleme que toi (je crois) pour les épisodes de 24 (video standard, son standard, version non réencodé pass nikel sur pc et sur archos avec décallage son/image, version réencodée passe nikel sur pc mais pas sur l archos). Je me suis apercu qu en effectuant un découpage des premières secondes, la video se lancait mais elle se bloquait à lorsque y a l'heure chrono qui s affiche (si vous avez jamais vu 24 ca correspond a un ecran noir avec l heure qu il est dans la série..) Et si je passe ce passage en accéléré la lecture continue. J en suis arrivé à une conclusion sur une possible raison du non fonctionnement : (attention peut etre grosse connerie) PDE en réencodant fait quelque chose de bizarre lorsque l image correspond a un ecran completement noir qui fait une sorte de coupure ou je ne sais trop quoi qui plante la lecture par l archos de la video. En effet, chaque moment ou la lecture plante correspond a une seconde d'ecran noir.. (j'espere que je ne suis pas trop ridicule avec mon hypothese) voila, bonne soiree PS: j ai essayé de réencoder avec divers configuration et avec la version 3.5 et toujours le meme probleme.. Ce message a été modifié par paixao: Sunday 29 January 2006 à 19:20 |
Sunday 29 January 2006 à 22:26
Je confirme, en sautant le début ça passe.... enfin la je ne comprends rien c'est certainement pas la première qu'il y a du noir dans une vidéo^^
Monday 30 January 2006 à 14:24
Oui je sais c est une proposition qui a l'air stupide mais pour les vidéos de 24 ca correspond exactement a ca..
Peut etre Wildelnab pourra nous éclairer.. |
Monday 30 January 2006 à 21:54
![]() Developpeur de Pocket Divx Encoder ![]() ![]() ![]() ![]() ![]() ![]() Groupe: Membres Messages: 1125 Inscrit: 18/04/2004 Membre No.: 520 J'ai : AV5100 |
Je cherche et je regarde...
Je suis en train d'analyser la vidéo de m&ms, mais je ne trouve pas ce qui pourrait clocher... Peut-être le noir effectivement ou alors il y a 2 keyframes consécutives, quelque chose comme cela.... Au fait, question bête : c'est sur un AV300 que vous essayez de lire vos vidéos ? A+ -------------------- MobaPhoto - Logiciel gratuit de redimensionnement, création de galeries et retouche de photos par lot en 2 clics
Tuesday 31 January 2006 à 15:30
Moi oui... pour paixao jocker^^
<= pour rappel du premier topic
Je suppose que si tu poses cette question, c'est parceque ça passe sur ton av500 :/ Ce message a été modifié par m&ms: Tuesday 31 January 2006 à 15:30 -------------------- Si tu utilises Firefox 2, n'oublie pas ton dictionnaire : Rajouter le dictionnaire et Option/Avancé/Général/Vérifier l'orthographe lors de la frappe.
Tuesday 31 January 2006 à 19:30
Merci de t'intéresser...
Effectivement moi aussi av320. J enverrai demain un court sample de se qui fait planter ma lecture... Ciao edit: voici l'adresse à laquelle se trouve le petit sample dont j avais parlé : [URL="http://condomizeme.free.fr/2-24 Heures Chrono 13H-14H_Archos_.avi"]sample[/URL] Ce message a été modifié par paixao: Thursday 02 February 2006 à 13:46 |
Thursday 09 February 2006 à 15:31
Novice ![]() Groupe: Membres Messages: 1 Inscrit: 15/12/2005 Membre No.: 3785 |
J'ai également des problèmes de lecture sur AV320 (reçu très récemment), j'utilise PDE 0 3 60 0. Parfois la vidéo commence puis se bloque avec comme message Impossible de lire la vidéo vérifiez SVP Ca le fait avec plusieurs vidéos réencodées( orange mécanique, les chevaliers du zodiaque, city of the men), pafois elles commencent et s'arrêtent, je peux les reprendre à un autre endroit et elles s'arrêtent de nouveau; parfois elles ne commencent pas du tout. (par contre pas de problème avec les 24 sur la saison 3...). Merci |
Tuesday 07 March 2006 à 11:16
#9
juste un petit up pour savoir si Wildelnab tu avais pu jeter un petit oeil sur le probleme |
Thursday 16 March 2006 à 21:04
#10
Salut,
Oui, je suis toujours sur ce problème... Je ne sais pas vraiment d'où ça vient. Il faudrait que tu utilises une version plus ancienne de PDE en attendant que je corrige le problème parce que je ne pense pas que ce soit pour tout de suite. Par contre, si tu peux garder l'original vidéo qui plante ainsi que les paramètres d'encodage, ce sera très utile pour vérifier que ce bug est corrigé dans la prochaine version A+ -------------------- MobaPhoto - Logiciel gratuit de redimensionnement, création de galeries et retouche de photos par lot en 2 clics
Thursday 16 March 2006 à 21:42
#11
Ca tombe bien j'ai trouvé une deuxième vidéo qui ne fonctionnait pas
Version bas débit | Nous sommes le : Monday 20 May 2013 à 21:49 |
