Thursday 24 November 2005 à 18:41
![]() Membre Hyper Actif ![]() ![]() ![]() ![]() ![]() ![]() Groupe: Modérateurs Messages: 1797 Inscrit: 11/08/2003 Lieu : paris Membre No.: 284 J'ai : Rien |
Version 1.2.20
----------------- New features / Improvements - USB Host: mass storage digital cameras, compatibility improved ( notably Pentax Optio S40 ) - USB Host: added support for PTP digital cameras ( Picture Transfer Protocol, used by Canon Ixus 40 or Sony DSP 72 for example ) - USB Host: mass storage mode, warn user when trying to connect NTFS-formated drive - USB Host: can now connect 2 Archos devices with a USB cable, when in Windows Device mode, for direct transfers Bug fixes - UI: popup menus not cancelled properly after changing the cursor position inside - Browser: Fixed the first item of current folder is faulty focused after adding/inserting a folder/playlist in a playlist - Audioplayer: Fixed wrong current song info in audio player after selecting an empty folder with the browser. - Playlists : a loaded playlist is added to the playlist in memory only if the playlist panel is open - Arclib : do not update arclib at each boot if no content at all on the hard drive - Arclib: automatic arclib not updated after copying a music file into /Music - Arclib: useless update the arclib when entering the music browser after recording a video - Photo: while in slideshow, USB MSC can be connected, but slideshow does not stop and kills USB - Videoplayer: Fixed the video resizer - Some 5/3 movies (e.g. 640*400) were incorrectly resized in "Original picture" mode - Videoplayer: the OSD is repainted incorrectly if a USB cable is connected then disconnected while playing back a video - Videoeditor: edition markers are not displayed when edited video name don't fit in status area - Info/Help: removed the commands Move/Copy/CopyAll from the menubar of the Info/Help browser - USB Host: after copying a file from distant to local, the file was not exposed on the PC if in Windows Device mode - USB host: "Move folder" from a USB device does not work, did move folder into the root of USB device -------------------- |
Thursday 24 November 2005 à 18:49
![]() Membre Actif ![]() ![]() ![]() Groupe: Membres Messages: 322 Inscrit: 02/11/2005 Membre No.: 3385 |
Bon, rien extraordinaire
-------------------- Bonjour... et Merci
Thursday 24 November 2005 à 19:20
![]() Membre Hyper Actif ![]() ![]() ![]() ![]() ![]() ![]() Groupe: Newser Messages: 2902 Inscrit: 10/08/2003 Lieu : Lyon Membre No.: 283 J'ai : un PMA et un 605s |
J'arrive pas bien à comprendre celle là :
"- USB Host: can now connect 2 Archos devices with a USB cable, when in Windows Device mode, for direct transfers" altavista me dit : "le bidon relient maintenant 2 dispositifs d'Archos à un câble d'USB, quand en mode de dispositif de Windows, parce que dirigent des transferts" plus sérieusement, je sais pas si ça permet de faire des transferts entre deux archos sans que l'un d'entre eux passent en USB, ou ça permet de les chainer quand on fait des transferts avec le PC... (ou alors c'est carément pas ça). -------------------- You have the right to remain silent.
Thursday 24 November 2005 à 19:56
Membre Actif ![]() ![]() ![]() Groupe: Membres Messages: 490 Inscrit: 12/01/2005 Lieu : le havre, rouen et calais Membre No.: 1622 |
je pense que ca veut dire qu'avant, un Archos qui était en mode "appareil mobile" et pas en mode "stockage externe" ne pouait pas être reconnu par un autre Archos lorsqu'ils étaient reliè par usb.
maintenant, ça doit être possible |
Thursday 24 November 2005 à 23:19
Novice ![]() Groupe: Membres Messages: 6 Inscrit: 23/11/2005 Membre No.: 3570 |
En tout cas, pour moi, ce nouveau Firmware me permet de connecter mon Ixus 40 en USB Host.
Celà fonctionne du tonnerre ! Merci ARCHOS ! |
Thursday 24 November 2005 à 23:21
Friday 25 November 2005 à 11:33
Membre Actif ![]() ![]() ![]() Groupe: Membres Messages: 264 Inscrit: 23/09/2005 Membre No.: 3119 |
Ca veut dire que tu peux, avec un câble USB (mâle, mâle je pense), connecter entre eux 2 AV500 et faire du transfert direct |
Friday 25 November 2005 à 12:12
s'ils ont ajoute le support PTP au firmware, la gamme EOS digital Canon devraient normalement etre entierement compatible... (je dis bien "mormalement")...
je confirmerai ca tout a lheure... -------------------- |
Friday 25 November 2005 à 12:56
#9
![]() Membre ![]() ![]() Groupe: Membres Messages: 158 Inscrit: 14/10/2005 Membre No.: 3259 |
Et mon disque dur externe n'est toujours pas reconnu ... snif snif
Si quelqu'un a un DD externe qui est reconnu il peux me donner la marque et la réf pour que ej change le mien !!! -------------------- lecteur d'aujourd'hui: AV 530
Lecteur d'hier:XS200, AV400, AV700 Lecteur de demain: Un archos 605wifi 160go |
Friday 25 November 2005 à 12:58
#10
Je voulais savoir la compatibilité est en fct du DD ou du boitier ?
Friday 25 November 2005 à 13:15
#11
![]() Membre ![]() ![]() Groupe: Membres Messages: 127 Inscrit: 02/10/2005 Membre No.: 3183 |
Je ne savais pas qu'il y avait un nouveau firmware, je vais aller voir de suite !
-------------------- Archros de la "technologie élégante" ...
Friday 25 November 2005 à 13:18
#12
Membre ![]() ![]() Groupe: Membres Messages: 122 Inscrit: 30/07/2005 Membre No.: 2799 |
Hourra ça marche!L'EOS20D est enfin reconnu!Je pense qu'il en va de même pour le reste de la gamme Canon.
Friday 25 November 2005 à 13:37
#13
C'est au poil ! Mon APN SONY est enfin reconnu !!
Par contre je n'arrive toujours pas à y relier mon caméscope JVC GR-DF540E ... -------------------- Archros de la "technologie élégante" ...
Friday 25 November 2005 à 14:48
#14
![]() Membre ![]() ![]() Groupe: Membres Messages: 58 Inscrit: 23/08/2005 Membre No.: 2937 |
Je suis en Argentine et vider la CF de l'APN c'est galere donc oui ca serait l'ideal ! |
Friday 25 November 2005 à 16:09
#15
![]() Novice ![]() Groupe: Membres Messages: 42 Inscrit: 25/03/2005 Membre No.: 2055 |
J'ai un Canon Powershot A400, vous croyez que ca va marcher? Je n'ai pas encore recu mon AV530 (petit probleme logistique) et je commencais a serieusement envisager la vente de mon Canon pour acheter un autre appareil, mais s'il est compatible maintenant..............
Friday 25 November 2005 à 21:50
#16
![]() Administrateur / Webmaster ![]() ![]() ![]() ![]() ![]() ![]() Groupe: Administrateur Messages: 6696 Inscrit: 09/03/2003 Lieu : Rennes Membre No.: 18 J'ai : PMA430, 605 Wifi (AV430,604 Wifi just vendus) |
Canon A70 marche d'apres un pote
-------------------- 10% de réduc sur les accessoires de Newmp3technology : coupon JBMMFR
10$ de réduc sur hotmp3gear.com : coupon jbmm.fr |
Friday 25 November 2005 à 22:37
#17
canon A75 pas compatible (bien que PTP)
Saturday 26 November 2005 à 00:55
#18
Membre Actif ![]() ![]() ![]() Groupe: Membres Messages: 272 Inscrit: 07/10/2004 Membre No.: 1052 |
Chez Pentax effectivement y'a du mieux, enfin la reconnaissance...
Saturday 26 November 2005 à 09:44
#19
Ce qui m'embete c'est que je ne recois mon AV530 que vers la mi-decembre, en attendant je me demande si je dois garder mon Canon (j'en suis tres satisfait) ou le vendre.....quelqu'un peut-il me conseiller?
Saturday 26 November 2005 à 10:38
#20
![]() Membre ![]() ![]() Groupe: Membres Messages: 56 Inscrit: 21/06/2005 Lieu : Domalain / Bretagne Membre No.: 2525 |
Ouais le pote c'est BCORGAN et il confirme que le Canon Powershot A70 fonctionne bel et bien !!! Merci ARCHOS !!!! Mais c'est pas trop tôt !!! Même si je viens de recevoir mon AV530 hier, je pense aux autres qui ont tant attendu Au passage, je remercie Scott de Hotmp3gear pour la rapidité de l'envoi : 3 JOURS !!! Je suis sur le c.l !!! Ce message a été modifié par bcorgan: Saturday 26 November 2005 à 10:40 -------------------- Editor man !
Version bas débit | Nous sommes le : Thursday 23 May 2013 à 14:22 |
